Looks to me like the M105 trailer frame welded or bolted to the deuce frame.Its hard to tell, is that a 105 frame under the stock frame? If so how did you connect it?
It is the a3 frame with the over loads, a3 frame is wider than deuce frame. Very good contact surface to weld. It is also bolted. I really like the recessed tail lights in the a3 bed and also the fold down ladder.Its hard to tell, is that a 105 frame under the stock frame? If so how did you connect it?
