Jackel44
- 0
- 0
- Fremont Nebraska
I just bought a 84 m1009. Before I bought it, I test drove it for about a half an hour. I came back 2 days later and payed him for it. I drove it home (about 45 min drive). I ran some erans. Starting it about a total of about 5 times. On my way home the water in fuel light came on. I went to drive it the next day and it turned over, but would not fire. I spent the next day reading on this forum.
Things I have done not in order:
The tank was about 3/8 full, I added 5 gallons of fresh fuel.
I changed fuel filter and used my vacuum pump to get air out.
I turned it over with a jar under the bleed hose and it placed about 1/4 inch of fuel in a short burst. (fuel was slightly yellow in color)
I removed batteries and and had them load tested and charged up.
I checked all glow plugs and they are all good.
I checked 4 glow plugs and they turn on and off when they are suppose too.
I checked the pink wire going to the fuel shut-off and when you turn the key it gets power.
I ordered a gp board from antennaclimber (knowing that was not my problem)
I have on order from napa the gp relay and the relay to do the doghead starter mod.
Change all glow plugs
My next steps in my mind. (again not in any order)
Get a tachometer and see if the starters are turning the engine fast enough.
Check compression (when I change glow plugs)
Change the fuel cut-out solenoid
put a fuel pressure gauge on the out of the filter to see if I have appropriate pressure.
What do you think I should do next?
