74M35A2
- 342
- 83
- Livonia, MI
Another "Don't Use Low-Reverse on 939 Series" Thread? Yes, But Fact Finding...
The "Don't use low-reverse" on M939 series seems to really have a mixed bag of emotions and outcomes. What I'm trying to decipher is, are there any cases of the T-case breaking from low-reverse usage with the front axle drive off?
I see carnage pics of broken ones, I read the stories, various threads, and I also see people say they do it all the time with no ill effects. I have even read one story where somebody says simply the slam of shifting the trans into reverse cracks the T case housing. I want to use low range to climb hills, pull stumps, and go over cars at the junk yard, etc...., but I don't want to shift into high range to simply back the truck up under its own weight only with little to no additional load.
Bottom line on top, are there any known cases of the T-case breaking by simply backing the truck up in low-reverse with no additional load on the driveline, or even just putting it into reverse? If so, then I'll pass on doing so myself, and maybe even pick up one of the GL auction T-cases that are new and piled up at the Ohio outlet (if these fit).
