Another engine noise video
fpchief
229
South Alabama
Been around HMMWV's since early 90's and dont remember a high pitched whine coming from the motor. Not like this. The sound it in the video if you can weed through the normal rattling shitbox sounds. I have a squeak up front from what I think is the idler and I thought this was from that but this 100% sounds central to the motor. Any ideas would be great. On the same note, those takeouts from eastern surplus....rolling the dice?
NDT
7,518
Camp Wood/LC, TX
Sounds a little like coming from the alternator. Take off the belt and see what you hear.
Action
1,564
East Tennessee
Hold a 3' piece of hose to your ear and move the other end around engine to find source. This is a lot easier with the cooling fan under the radiator. I had a squeak that ended up being a crookedly mounted alternator bracket. Re installed that bracket and whine went away.
Andyrv6av8r
458
Spartanburg,SC
I was attempting to install a new serpentine belt, which was too long, and discovered my AC delete idler has a bad bearing. Mine had a squeek similar to yours. A new one is on the way.
fpchief
229
South Alabama
Thank y'all for the replies. I know the squeak near the tensioner goes away with no belt. Will get it hot and take belt off tomorrow and see about this sound. Pretty sure not alternator just does not sound over that way but will definitely find out tomorrow, will use the hose like Action said!
The other pulleys are all new with exception of belt tensioner which I need to stop being a cheap ass and buy. Will update tomorrow on the sound.....and start posting pics of my spare tire carrier build (Andy)....
Mogman
10,595
Papalote, TX
Just be DAMN aware of what you are doing with the hose. don't want the fan or a belt taking it away from you and beating the crap out of you!!!
