DeadParrot
- 46
- 28
- oklahoma city, ok
Picked up my M1101 from Ft. Sill on the 28[SUP]th[/SUP]. The GL lady was very helpful and the paperwork only took a couple of minutes. She has too much fun driving the forklift but is very good with it. No EUC needed on this one. The tires had less than 10lbs but a portable air tank had them up to the 14lbs the TM specified. Had a pre-made flat 4 wiring harness made up and after swapping out the 24v for 12v bulbs all the lights worked. The clearance lights are all LED. The drive home to OKC was uneventful. When I did a hub check stop after 10 or so miles, the hubs were not even warm.
It is a 2009 build. One oddity is the data plate shows a 2/28/2009 delivery date while the axle tag shows a 3/31/2009 date. Guessing the chassis is built in one place and mated with an axle somewhere else.
One nice thing about Oklahoma trailer laws is non-commercial trailers have no registration/license/title requirements. The MV dept. even has a letter in PDF format that spells this out. They recommend you carry a copy if traveling out of state.
The trailer has a few small dings and dents. One of the small outside tie down loops is somewhat smashed. It so far appears to be otherwise in excellent shape. The paint is somewhat faded as the paint under the rear support feet is darker. I found that Rustoleum 7771 Sand is a close match. The satin/flat variant might be even better but gloss is what Home Depot had. There is a before and after shot of the rear of the trailer.
