Woodsplinter
- 6
- 18
- Phoenix/AZ
Hey folks, I've read many of the threads about leaking hydraulic heads but I'm not sure which direction to start in.
Mine started leaking on my A2 deuce yesterday. (LDT465-1C engine) The first photo shows a pencil pointing to the area where the leak appears to be. (At least in that area).
I have verified all the injector lines are tight as are all the mounting bolts. The truck runs fine and always has- just sprung a leak.
I removed the cover on the lower portion of the HH where the stop cable enters and found it filled with black oil. (Only run diesel, never WMO) Turned on the in-tank pump but saw nothing leaking. Only appears to leak after running for a few minutes. While running, I could see fuel dripping in the area of the pencil tip.
I'm not sure which direction to go next- replace the HH, just the O-rings??
I've read TM's till my brain is mush (not really much different than normal-lol).
Any advice would really be appreciated!
