Another M1010 owner
Mad Texan
1,151
Chester County, PA
I got latches installed on the drawers. Should hold them closed when they are full of stuff. Also made a cover for the rear slider. Proceeded with the sanding and finishing. I’ll probably do one more coat on the top surface... still waiting on the 3/4 Baltic birch for my other sliders...🤬. Oh well, been working on her and driving her the past week! 🇺🇸🇺🇸🥓🥓🥃🥃
Mad Texan
1,151
Chester County, PA
I’ve been wanting to upgrade from the single rv fixture for lighting in the box of the M1010. But I didn’t want to lose headroom being tall myself. Extrusion is 3/4” wide and 1/4” thick and 4’ long. I’ll need to do a little paint touch up. And there is the second setting in case we go to DEFCON 1... 🇺🇸🇺🇸🥓🥓🥃🥃
Another Ahab
4,940
Alexandria, VA
It's shaping up beautifully, Mad Texan. Nice!
What's your plan on a mattress for the rack (not your standard size):
- Just a camping pad and a bag?
Have you had time to think about that yet?
Mad Texan
1,151
Chester County, PA
The plan is a futon mattress to double as seating (couch). I actually shopped them for size as I initially was doing my design. I found one I want, but you got to love this, to buy it I have to get a prescription from a doctor because it's chemical free. 🤦‍♂️ Yep, that's a law... 🤷‍♂️aua:shrugs:
Another Ahab
4,940
Alexandria, VA
What you need is a just a Rock-N-Roll Doctor:
- Doctor of Heart and Dcotor of Mind
Mad Texan
1,151
Chester County, PA
I finally got the 3/4” Baltic birch plywood for my table and fridge sliders. Doing a dry run before applying finish to them. I ended up with plenty of clearance between the table and the fridge. 🇺🇸🇺🇸🥓🥓🥃🥃
Mad Texan
1,151
Chester County, PA
That little "pony" refrigerator is a great item:
- How did you find that?
They are very common in the Overland community. They are very energy efficient and will run on either AC or DC current, should pull a max of 2.6 amps on 24v. This one even has a freezer section which I have successfully made ice in. Dometic, ARB, Engle, Indel B, National Luna are a few of the manufactures of them.
Mad Texan
1,151
Chester County, PA
Back to some more finishing on the panels for table and fridge. I really like how this Waterlox lays down, two coats, scuff it, lay down the third coat then wait a few minutes and smooth it out. All with a foam brush. All slides from ovisonline.com, good prices, great service and support! There’s a lot going on in the back corner... 🇺🇸🇺🇸🥓🥓🥃🥃
Mad Texan
1,151
Chester County, PA
Are the blue poly jugs your water supply, Mad Texan?
Got them on a pump of any kind?
They basically are... one fresh and one grey waste. Those same jugs also fit in the passenger side storage area as well to carry more fresh water. I have purchased a hand pump faucet but I am also looking at a 24v electric pump that would be controlled by a switch on the faucet. I just haven't made a final decision on that.
