Another Muffler Thread - The one I chose and why.
talskinyguy
DeKalb, IL
I had 2 goals when adding a muffler
1. As quiet as possible.
2. Not choking the engine so much that I burn something up.
The first step was figuring out the CFM of the exhaust.
I used this from donaldson's website to figure that out.
http://www.asia.donaldson.com/en/exhaust/support/datalibrary/1053747.pdf
I came up with an intake CFM of 540 using a VE of 1.5, but the stock air filter is only rated for 410 CFM from what I can find, so I'll just work with both numbers.
This gives me an exhaust CFM at 1000 degrees of 1108 if I assume 410CFM intake, and 1460 if I assume 540CFM intake.
At this point I decided to use the numbers that went with 410CFM intake since that is what the intake filter is rated for. This seems to assume a VE of 1.12 for the math to work out, which seems low for a turbo engine, but the intake is going to restrict flow at this point anyways.
The form from donaldson also said to not exceed 3 In HG of exhaust pressure, so I am looking for a muffler that flows 1108 cfm at 3 In of HG.
I found this Donaldson muffler M090146 with the following specs.
Inlet Diameter:3.50 Inches (88.90 MM)
Outlet Diameter:3.50 Inches (88.90 MM)
Body Diameter:9.00 Inches (228.60 MM)
Body Length:44.50 Inches (1130.30 MM)
Overall Length:51.00 Inches (1295.40 MM)
Rated Flow LR:578.00 CFM (16.3574 CMM)
Rated Flow MR:817.00 CFM (23.1211 CMM)
Rated Flow HR:1010.0 CFM (28.583 CMM)
Back Press LR:1.00 In Hg (25.40 MM Hg)
Back Press MR:2.00 In Hg (50.80 MM Hg)
Back Press HR:3.00 In Hg (76.20 MM Hg)
Attenuation:19-25 dBA
And this is where my compromise came in.This muffler has the most sound reduction rating by nearly 10dBA that I could find. And how often am I sitting at 2600 RPM and running full throttle? In my experience never. 2400 RPM gets me back down to a flow rate that causes less than 3 In HG and I am rarely ever full throttle in that scenario either.
This math is based on my own assumptions of how I drive and my fuel pump not turned up at all. I will be getting an EGT gauge in the future to make sure that I don't burn anything up, because this amount of back pressure will definitely make my EGT's raise faster, but I don't think they will get to any dangerous amount with the way I drive the truck.
Then again maybe all this math is garbage on this engine because the head doesn't flow worth a **** or something. Because it is generally agreed upon that its 1.5 cfm intake to each hp and 2.2-2.3 cfm exhaust per hp. If that is true then I'm below even the 1 In HG number for this muffler at max hp of the engine.
talskinyguy
DeKalb, IL
This muffler is massive. More to come when I install it.
Also other mufflers cross reference with this one, but from what I have found they are the same in physical dimensions only. They are all straight through and therefore would not have the same sound reduction.
1,184
Just search "M090146".
talskinyguy
DeKalb, IL
That is the muffler I have, and the part number listed in my post.
If you quieten your exhaust, you will recognize all the other noises :D ... insulate your cab and hood. that will help a lot.
I would have to put a top on the truck for it to make a big difference. But I will be looking at ways to quiet it down more once it warms up and I start driving it more.
