another no power/ no lights question
kcbbqguru
kansas city
I went to drive my truck sunday, turned the key, and dash light went out, no power
checked batteries with load tested and tested fine. Had the wife come out to turn key, took the jumper from
front battery to rear battery and go power to dash, and would even turn engine but not enough power to start.
put battery post back on and nothing?
thanks
Barrman
1,653
Giddings, Texas
How did you load test your batteries? You either have a bad battery, loose or corroded connections or now that you tried to turn the engine over with the smallest wire from the batteries. A burned fuseable link.
Start with checking the batteries separately with a real carbon pile type load tester.
kcbbqguru
kansas city
thanks Barrman,
It's amazing what 2 brand new batteries will do to start a truck, old ones had bad cells, now need to trace the why the headlights not working!
