davo727
- 2
- 18
- Cleveland, TX , Spring , TX
This is a borg warner BWD S5049 lifetime warranty relay from oreillys. $24.99 + tax, it is a starter relay for a 97 Ford F350 diesel.
Connect the purple with white stripe wire to the S terminal. The small black ground wire is connected to the case ground of the relay with the bracket attach bolt.
I also crimped in another wire in with the ground that I ran to a ground lug on the inside of the firewall near the base of the steering column.
Do not connect anything to the terminal marked ( I ) on the relay or bad things will happen .
Red Power in to the B terminal, purple power out to M terminal.
