Another way to filter WMO Idea!!!
Hooty481
Russell County Kentucky
What about taking the filtering system from a parts deauce and useing for the filter setup. They should be readily available. The filters are a 10->6->6 micron rating. all that would be needed would be a pump and a tank. The deuce fuel tank and pump should be easy access as well. Just my 2 cents. I will begin construction he shortly after I leave work and report back with the results!
Open to criticism and bad jokes no good ideas please.
Jimma
Hartwell, GA
Its funny that you suggest that because that is exactly what I was thinking about yesterday. With so many people having either parts trucks or removing things to replace filters with spin ons. There are canisters going to waste.
gimpyrobb
dumpsterlandingfromorbit!
27,787
776
Cincy Ohio
This was what I did for my first filtering setup, only I used a pneumatic barrell pump instead of the stock in-tank pump. The filters work well, but I bet using that pump will be SLOW. It is not a high pressure pump, and when the filters plug, it will block flow. You might even burn up the pump.
kipman
15
Lancaster Ohio
My first set up was with the deuce filter cans, used a hydraulic pump, worked OK, but have switched to using a air powered pump, like it mo better.
gimpyrobb
27,787
776
Cincy Ohio
With as much as an in-tank pump costs, I would not chance ruining one that works. Put it in the spare parts drawer.
