Bigsampson
- 0
- 1
- Fort worth
Looks like you welded the aluminum plate to the steel frame??Another way of going about it.... I did ditch the shocks.
Sorry - missed this....Looks like you welded the aluminum plate to the steel frame??
Man, maybe this is the push I need to finally buy the cordless jigsaw I've been eyeballing but never buying. I cut mine with a Hackzall, and "like butter" is not in any way how I'd describe it... I think I spent about 40 minutes making the 4 long cuts, with fresh blades, and used about 20aH worth of M12 batteries.Then to cut the metal structure off the trailer I used a jigsaw with metal cutting blades which sliced through it like butter.
This is probably ancient history to you but I'm curious about the trailer you lowered using 2 1/2" square tubing, ripped in half, to form two U-shaped pieces. Has there been any evidence of structural weakness in the U-shape vs. square? How critical is it that the cut sides (facing up and supporting the frame) be exactly flat and parallel? I have a plasma cutter but not completely comfortable in my precision. Lastly, how can the axle be moved forward by 1/2" on the 1st one, 3/4" on the 2nd one, and 1-1 1/2" on potentially a 3rd one and still all look centered? (sorry, not trying to be a smart ass by asking, maybe there's some kind of arc thing happening as the trailer lowers, the wheel moves back?)Third time is a charm!! I lowered another one today, and it's even better than the first two! (I can do it start to finish in about 5 hours now, by myself.)
The other two are lowered 2-1/2", and the second one I did I also slid the axle forward 1/2", which worked out well. (More shock length, and still looks centered in the wheel opening.)
Today I cut my 2-1/2" square tube lengthwise down the middle, so I got two U-shaped pieces that were each only about 1-1/8" tall after I cleaned them up. I pointed the legs up, against the frame. It was a little tricky to get the bolts tight, but I managed. So this trailer is now lowered 3-7/8", and I LIKE it!! I also slid the axle forward 3/4" to add some shock length.
I had considered just letting the axle rest right against the bottom of the frame, but I don't think it'll work unless I leave off the shocks. Plus, this trailer looks pretty low now. I don't think I want it any lower.
One thing I did notice in doing all these trailers is that my two 2009 trailers have shocks that won't collapse the final inch of shaft into the body. The older trailer has shocks that do collapse completely. The fully collapsible shocks will work better on lowered trailers. I probably should move the fully collapsing shocks to the first trailer I did, since it's shocks only have 1/2" or so travel before they bottom. (I put zip ties on them and they don't even move 1/2" with me really shaking it around... even with 2000lbs of water, pump, and hose reel!)
I'll try to get a few pictures up tomorrow.
