antifreeze leak need part number ?
maxxplanck
Fowlerville, Michigan
I was just changing out my oil filter to spin on oil filters and I noticed a few drop of freash antifreeze behind the old oil canisters and then after looking around I found a few more drops. Its leaking from the short rubber hose behind the old oil canisters, does anyone have a part number for napa for the rubber hose ? There is also another short rubber to the left in front of the engine that should be replaced, I need the part number for that also. What A Day:( Thanks Guys Rich
M35A2-AZ
425
Tonopah, AZ
I got my 2" hose from Napa, I think it was $10 a foot.
The two little hoses on top are 1 5/8",
:beer:
jhooah
Carrollton/Virginia
While your at it replace (or check) the lower radiator hose. It swells and rubs the crank damper which then cuts through and bursts under pressure at the worst time....
This is replaced with a Ford F250 or F350 460CI upper radiator hose trimmed down about 2" in length. Can't tell you the year, but '75 up to early eighties should fit. It's just a long pre-formed "L" shaped hose.
Cheap insurance for all that anti-freeze and peace of mind.
V/R W Winget
Carrollton, Va.
M35A2-AZ
425
Tonopah, AZ
I was looking at my TM 9-2320-361-20 ( 3-48 oil cooler tube and hose replacement ) page 3-108 these are the two hoses that I need to replace. Not sure if there 2" or 1 5/8" ?
Maxxplanck, I used 2" hose on all the hoses on the front and the oil cooler side and 1 5/8"on the top of the motor for the two little short hoses.
If you change the two little ones on top your going to need some gaskets for the manifolds.
I just did the two on top this weekend on my motor and now all the hoses or changed. HA!!
I did buy a L shape hose for the lower radiator hose from one of the retailers.
