This thing was sitting on the ground in gravel it had 3 windows and 3 pop out vents on each side of it like on the sleeper of a tractor trailer with big opening on back missing the barn doors that came with it !I seem to remember that I put the MWO book into the TM section. If you mean the hard top with storage space in both sides?
Did you hear anything from your friend on the hardtop?No, not what I posted. You got a picture? I know maybe someone who has some info on it.
Thanks i had found that a while back im trying to find out the M- number like m-1095 or what ever might make it easier to find under the proper call sign .AMTECH makes 2.5 and 5 ton truck versions
LMTV 2.5 Ton - McClarin Composites
HELMET HARDTOP® : 2.5 TON LMTV The LMTV HHT CBC was designed with snow load in mind. Weighing in at just under 650 lbs. The Standard LMTV HHT CBC roof is capable of carrying over 3500 lbs. of snow load with minimal deflection. Standard features include but are not limited to pad lockable rear...www.amtechcorp.com
There are only M numbers for vehicles/trailers/equipmentThanks i had found that a while back im trying to find out the M- number like m-1095 or what ever might make it easier to find under the proper call sign .
Thats even cooler ! I thought it might have a number like s-250 s 280 or something!!! No worries ! Do you ever run across either one of the hard tops ?There are only M numbers for vehicles/trailers/equipment
This is the pop up version
It's just a helmet top. Not a shelter with a designation. I've seen them at yards just not that common unless it's on a hmmwv.Thats even cooler ! I thought it might have a number like s-250 s 280 or something!!! No worries ! Do you ever run across either one of the hard tops ?
The picture i posted above for the 5 ton is the only one i ever saw on gp and it went thru twice to finally sale out of kansas base it had the big red scorch mark on its side and it went for 1200 best i remember but i searched that and it was already removed i beleave it was in 2018I know they are limited in surplus/civilian hands. A few FMTV shells got out a few years back through GP but they were rough and just the shell. No doors, windows, locks, etc. They'd be awesome to have for sure! I managed to grab an LTT (for HMMWV) by accident that was still in the crate and AM General came knocking on my door wanting it for a project.
Thanks across the pond !My buddy told me, just like Simp wrote, no M-number. He also said that it might be listed in the TM9-2320-333-10HR or TM9-2320-333-14. Its been a while since he saw one, and is not real sure what TM its in, but was fairly sure, its listed in the TM.
COPY DITTO!My buddy lives in El Paso, Texas. I will forward your thanks!! take care and be safe!
