Any difference in "early" 5 ton axle-side steering arms?
Trango
23
Boulder, CO
Hi Gang,
Synopsis:
Did the early M39 / M809 series trucks ever see any difference in steering arms on the axle? Meaning, was there ever a shorter or longer example?
Details:
My 5 ton-based project is continuing, slowly. I'm now looking at an interference issue between the steering arm on the axle and the U-bolts on the front driver's side leaf spring. Bottom line - my leafs are slightly outboarded from frame width and this is causing interference at the with the swing of the steering arm (as it bolts on top of the Kingpin).
I could cut, section, and reweld the arm I have (yes, I am familiar with this as well as the caveats), but I am wondering if there is perhaps a model that is just shorter than what I need.
The arm I have is 9.5" from top Kingpin center to middle of Tie Rod End.
Thanks in advance for any thoughts or help.
Best,
Bob
OSO
Arlington,Wa
On my M328 Bridge support truck the pitman arm is over 9.5" , the arm starts out I think past c/l of left wheel . I will measure it on Wed. Will post legnth.[thumbzup]
73m819
319
gainesville, ga.
use a m54 (early 5t) steering, it does NOT have the RIGHT steering arm or hydraulic cylinder , the 809 5t series has different steering with a hydraulic cylinder.
By the way, Im looking for a 5t front spring perch and a RIGHT steering arm
Trango
23
Boulder, CO
Thanks! Specifically looking for an arm that's *shorter* than 9.5" between centers of kinpin and Tie Rod End.
Best,
Bob
73m819
319
gainesville, ga.
BOB, the 9.5 RIGHT arm is ONLY used on the 809 series, the 54 series DID NOT have a RIGHT steering arm, same front axle only different steering actuation
USMC6062
St Augustine, FL
If your looking for a shorter left steering arm, you can use a right steering arm that originally connected to the hydraulic cylinder on later M54's and 800 series 5 tons. That's what I did on my bobbed truck to correct the steering ratio to work with my shorter custom made pitman arm.
