Any idea on what a White M2 is worth?
Dixiedog
Atlanta Ga
Was looking at a running White M2 but just do not know current values on these, any help would be appreciated .
Bradym114
46
13
Anita Ia
I'm looking at this as well, its set up as a m16, it should bring pretty high dollar. I'm betting between 30-40k. if your looking for a nice project I know a guy that has 2 halftracks with all the parts and repro rear armor to have both restored for 30k. They have been tore down and restoration was started, then the guy passed away.
AZDeuce
Tonopah, AZ
That is NOT a M2, you can tell by looking at the rear body and frame that it originally was a M3, I'm guessing a fairly early one, based on the serial number on the frame, and the headlights. Inside the rear compartment is set up as a M16A1, a lot of M3's were rebuilt into M16A1s. Ignore the data plate it is off another vehicle, the serial numbers don't match, and obviosly its a M3 based vehicle. What's unusual is the cut outs in the armor on both sides, the original M16s had those cut outs on the top 8" of armor that folded down. When M3s were converted to M16A1s since their armor did not fold down, they put an extra ring under the quad mount, so it would clear the stationary armor . I have never seen a M16A1 with those cut outs, I wonder if this was actually a prototype for the M16A1 and they decided a higher ring under the mount was a better/cheaper solution than cutting out the armor?
Definitely worth saving and fitting a quad mount in it, it would sure be unique.
WillWagner
2,698
Monrovia, Ca.
Guys, be mindful of talking prices here if you all are watching/bidding.
Dixiedog
Atlanta Ga
Thanks for the info!
