3000gt
- 0
- 0
- hernando ms
Have no idea
Have you checked to see if the engine still turns over?Brand new pump less than 30 miles
(FAN CLUTCH)I took it off and it appears to be okI agree with 86 humv...where's the fan clutch Assy..?? We all know what happens when a fan clutch seizes up...a real weird vibration right before the metal klunking sounds start. Also for the 25 plus years in the automotive industry, I have seen my share of brand new..not rebuilt parts fail before vehicle even leaves the shop bay. I think national average of parts failures in the automotive aftermarket is somewhere between 12-18%...which real is not that bad if it is viewed from an overall number of units sold...my 2 cents for what it's worth..
Purrs like a kittenHave you checked to see if the engine still turns over?
Bought pump at O-Reillysthat pump has a lot of rust stain. I know it has nothing to do with the failure but have you flushed the bottle, heater, and system. Mine was full of nice rusty sediment.
Belts too tight, fan clutch / pulley out of alignment, fan clutch studs/nuts loose, engine mounts worn causing movement are a few things that come to mind from my selling parts in another lifetime. You can see that kind of failure on very old high mile water pumps but should not on a new one. Problem is that most pumps now are made somewhere else. No one rebuilds them anymore. Everything is now new. What brand was the pump?
