any pics of fuel heater on 809's?
cranetruck
94
Meadows of Dan, Virginia
Hmm...can't see the oil pan shroud.
Custom made my battery heater since chances of find one for the m656/xm757 is nearly zero (the coolant connections are both to the side).
When using the heater, consider putting a time limit on it. The batteries could get pretty hot and 75-80°F is ideal. The coolant will get them way beyond that, I'm sure.
brianrbull
11
Casnovia Michigan
Jwaller, Do you know of any more of the Arctic parts that are avaliable? I am wanting to do this to my M816..... if you could point me in the right direction I would owe ya one...
jwaller
20
Columbia, SC
Did you buy a whole kit from someone or just pieces and parts?
thanks for the informative posts, I am gonna try to do this sometime also.
no one person had everything. I've been finding/buying pieces for a long long time to put together an entire kit.
I've never seen the lower arctic batt box or heater plate, not even on the museum truck I found. I also have a full set of cab insulation pads for the cab, but I'm not sure I'll ever install them.
