Any way to tell differential gear ratio without removing the cover?
hrbergeron
408
Geographical Center of Virginia
Is there any way to tell what gear ratio the differentials are without dropping the covers? I thought they were stamped on the side, but I can't find it. This is on a 1994 M998A1. Need to know the ratio for programming my transmission computer.
gringeltaube
Staff Member
2,682
Montevideo/Uruguay
With the TC in N, and wheels chocked.... jack up one wheel, then turn the other one 1 full revolution while counting the number (and fraction) of turns the drive shaft made.
That number, times two, is your ratio.
If you have a 2.73:1 ratio, your drive shaft will spin exactly 1.365 turns. Or 360⁰ plus another 131⁰.
For more precise results, turn your wheel 10 revs and then divide by 5 the number of drive shaft revs.
Note: Just in case, better do this on both, front AND rear differentials. We have seen cases of mismatched ratios, already...
See this thread...
