DDT
- 0
- 5
- Southern Cal
On a side note don't get crazy and take apart the vent side window while your in there! I recently bought all new seals and rubber trim for the windows and found out that the vent window is a sealed unit. They will sell you a seal but its seems that the windows is fixed to the frame of the vent window by a pivot post and a hinge. So good luck getting a seal over the 2 hurdels. My truck was down for 3 weeks because without a vent window frame you cant have the window flopping around in the door frame. One can by a new assembled window with the seal and glass matted together for $400 per side from Brothers in Corona CA. I just bought a clean used setup and a new vent window latch w/ o rings on ebay and the wind noise really went down!
