Anybody recognize this "Pickle" Forklift?
snowtrac nome
140
western alaska
FYI those mattracks arent as good as I thought they would be, but the truck could be partially to blame to. They bog down real quick in soft snow and they dont take bumps nearly as well as I thought they would. The steering is a PITA to at low speeds, you have to be moving to turn. The Grip-Trac's work alot better, higher ground clearance, heavier duty, dont bog down in the snow, just as hard to turn and just as bad on the bumps.
Matttracks can enhance mobility of a rig but they are no substitute fro a snow cat especially when you are loaded heavy. there is no substitute for footprint
NDT
7,287
Camp Wood/LC, TX
Anybody that has a pickle forklift with the 4BT upgrade, be advised the fuel solenoid is 12 volts, I put 24 to it and nearly caught the thing on fire when the solenoid and harness burned up.
EDIT: BAD INFO above, the solenoid is 24 volts, stupid me jumped the pull in wire to constant volts, this is only for momentary use, the hold coil holds the solenoid once the pull in coil has pulled in.
snowtrac nome
140
western alaska
That's good to know I want one of those bad out at my homestead the cummins conversion would be desirable. Those are handy little machines and they work well in dirt lots
simp5782
Feo, Fuerte y Formal
9,497
Mason, TN
A camera in front of the forks on the mast is handy. cause you really cant see where the forks are at when its on the ground really
Pop Alexandra
Cluj-Napoca
I had no idea.
Thanks for sharing... it should save people some awful experiences.
_________________________________________________________________
Alexandra from Chariots GCS
