Anyone have a Mep 802A fU1 FUSE or konow of an equivalent fuse (F03A125V30A) ?
kloppk
4,049
Pepperell, Massachusetts
You ought to be able to leave a jumper across CR1 as long as needed. It's there to prevent damage to the set in case the batteries get hooked up backwards.
The solar diodes will work.
kloppk
4,049
Be sure the sets have the Fuse Mod installed in them.
A copy of TM 5-6115-624-BD BATTLEFIELD DAMAGE ASSESSMENT AND REPAIR
How to repair and jury rig a set to get it working is a pinch.
Some good info in the thread about spares
Spare Parts
Also if not mentioned in that thread
A set of radiator hoses
Fan belt
Fuel pumps
Return fuel line
IP pump fuel hose
Well nut
Starter
Voltage Regulator
CR1
Water Pump
Engine sensors
S1 if the set has the failure prone blue plastic one
Rotor end bearing
A spare 803 :)
