Anyone have experience with these gensets?(Pow'r Gard / wisconsin Robin Diesel)
187
Youngstown, OH
I picked three of these up at Fort Dix while I was out that way today. Look like decent units. Haven't tried them yet. I need to get batteries for them, perform some maintenance, and fire them up!Gen2.jpgGen4.jpgGen5.jpg Gen3.jpgGen1.jpg
187
Youngstown, OH
They are about 150lbs +\-
Can't wait to try the electric start! Small units, but they should work well to help light our firearms range, or for other small emergencies.
They were requisitioned for use by another Government agency, so the cost was $0.
glcaines
2,465
Hiawassee, Georgia
I had one, but sold it before i got it running. They are very noisy due to a high run rate of 3600 RPM. All of the engine parts are still available new from Robin / Subaru. Do you have a manual? If you don't I can send you one on CD if you PM your address. The alternator is made by Baldor. Baldor also sells a wheel kit for the genset and other parts, such as fuel tank, etc. come from Baldor.
  • Like
Reactions: 187
ETN550
9
Knoxville, TN
I have had 5 of these units. They are pretty light duty. I have had a custormer fail 2 stators and I have failed one stator. The engine runs a little on the dirty side but is quiet compared to the Yanmars and it is very well balanced and smooth. Diesel fuel conditioner helps it run better. Weight is around 200lbs. 2500 watts is a decent load for them. I still have a ton of parts if you need anything.
187
Youngstown, OH
I got two of them running today. One is running really well. The second ran for a while and then quit. No fuel is getting to the filter after about 5 minutes of fuel flowing fine. The fuel hose is clear. I think the shut off valve on the bottom of the fuel tank is clogged.....probably from some junk in the tank. When I pop the fuel line off of the valve (with the valve set to "on") no fuel comes out. I will get that apart and clean it out.
#3 is being stubborn ad almost wants to start. Another project for tomorrow :)
ETN550.... Thanks I will let you know what I need.
1,806
Odd as it may seem, I ended up with GLCaines genset. Not 2 hours ago I started it for the first time. Search Steel Soldiers for 30D36R and you will get quite a few hits on them. Gary (glcaines) and neilhendrix have done quite a bit of research on them and scared up manuals and parts sources for them.
187
Youngstown, OH
I got all three running like a top! All load tested and good. Pretty neat little units. I only need a few feet of 1/4" fuel lines to make them almost perfect, and learn how to prime them. One had a badly clogged fuel valve at the bottom of the gas tank.
Thanks for the help!
