ApopkaFL
Banned
- 596
- 0
- 0
- Middlesboro KY
I want to post a couple of photos of a Deuce to see if anyone knows this truck?
Wow, thats a lot!
It almost seems that if you look at your truck wrong the fronts will rub just sitting there! What size tires are those? You don't seem to have much room for articulation in the front. How much tire would be outside the fenders if you could flip them around? Meaning, make the outside face you have now into the inside - touching the axle hub.
Looks like another thread he started and dosen't follow up on , no answer in 3 days but he has been on the site.What'cha postin' my truck for Rodman???
69 is for the year made... not it's weight
ApopkaFL he is almost your neighbor. lol
Ive never seen it around town myself but then again I dont hang aound Orlando area much at all.
Comments like this is the reason I stopped using this site.It seems to me that when the rim company was hired to modify the 5t wheels that who ever didn't do enough research to find that a 5t is different than a 2.5t and needs different back spacing. And in my humble opinion, it seems as if some one was greedy and went with gigantor tires that can't really function unless you suspension lift the truck.
I am stuck in the - "can't find an affordable machinist to do work for me" problem. I have 395's and FMTV wheels that need work. It seems that this tire size it the largest without rubbing (with the proper back spacing).
Search around, but there are accurate measurements on here for fitting certain size tires. The 395's that I'm going to run will have 8.88" (inside rim edge to inside plate face) or 3 3/4" from the outside face rim lip to the outside face hub center. But again this is for FMTV wheels and I don't know if HEMTT wheels have the same gigantor rim lip.
