anyone know what this is?
Sgt Hulka
San Francisco CA
Yup glow plug controller card plug in receptacle. Their should be a card plugged inside it and there should be a cover cap over it. Can't tell from the pic if it's there...
4bogginchevys
rathdrum idaho
my controller card is up under the dash, and yet I have a box just like that hanging down near the 4x4 lever, it's not 1 of the (2) relays that are attached to the starter relay mounting bracket....so my question is, what is it.....? Thanks again!
Sgt Hulka
San Francisco CA
BoT :-D back at you... I'm a bit of a newbie, but man. As you know I've been through the CUCV starting issues! (thankfully resolved BTW... intermittent bad gp control card)
1,172
I am guessing that you are talking about either the Tach Buffer Module or the Resistor Board, shown in the Diagnostics Circuits on the -20.
This is only needed/in use when using the STE/ICE test equipment.
Simplified Test Equipment / Internal Combustion Engine
steved454
brandon/ms
yep the card is in it and the cover too. I might be slow and stupid but I know better than to cut it off and throw it away! atleast for now :-D
