tm america
- 25
- 38
- merrillville in
i'm not calling them i dont have 5grand for a stock 3053a .i'm just thinking it would be better and probably cheaper to make a different set of input gears to go with bigger tires then it is to change the ratios in the rear end .not to mention the gear chances for the diffs are going the wrong way for bigger tires. they are made for light rigs running bigger power.i would like to come up with something beween the 3053 and 3052 and still keep od even if it wasnt as steep of a od .that way you could have more drivabilty at lower speeds and still gain just a little top speed .more less making a trans to match the mf power curve with 46-47 inch tall tires since there are so many guys running this combo .i know i'm not the only one encountering this problem
