06streetrod
- 0
- 0
- San Antonio, TX
first off, i wanted to say thank you. i've been searching these threads for weeks now, and have already found alot of answers. about a month ago i bought an 84 cucv that was sitting for a few years. when i bought it the guy said it didn't have a fuel filter and he never got around to installing one, and when he popped the hood, guess what was staring me in the face. so right off the bat i knew i was in for some work. was running alright for a few days.
here's what i've done so far...
-oil change
-new air filter
-new fuelfilter(of course)
-added injector cleaner to a newly filled tank
-took out elec gasoline fuel pump and installed new mech pump that went out years ago.
-replaced injector pump (went out 3 days after i bought it)
-had injectors tested (all good)
-thoroughly bled entire fuel system (3 times, positive there's no more air)
-replaced transmission vacuum lines that were falling apart
-new glow plugs (all of which are working properly)
might i add that the gp's i took off the right side were the right ones(ac delco, 10.5v) the exact same ones the parts store gave me, but the ones off the left side were bosch 11v. they wouldn't even fit back into the boxes when i was cleaning up the old gp's, they were too long.
now here's where i need help....
i'm getting the "continuous white smoke with diesel smell" i've seen a couple others here struggle with.
i can get it started, but it wants to die when it's running and i throttle up, and when the rpms come back down, it dies unless i bring the rpm's down slowly, and i have the idle adjusted all the way up right now.
it also dies when i put in into reverse or drive unless i give it a little throttle.
just took it for a drive around the block...
when i'm sitting still idling, and i give stomp the gas pedal, the engine responds immediatley and the "white diesel smoke" increases as well. when i put it in gear(with throttle so it doesn't die), the engine doesn't respond as well when i mash the pedal. it took me an entire block's length to get the speed up to 25. not to mention the intoxicating cloud that followed, which i'm sure the neighbors didn't like since the weathers nice and everyone's outside right now.
i am getting power to the pink wire on top of the ip also.
the only thing that i know of left to do is get the low and high idle adjusted, assuming i can get it to not die without letting the throttle out slowly, and to get the transmission vacuum valve adjusted.
so here's my questions......
will the transmission vacuum valve not being adjusted keep the engine from dying when i put it in gear and the slow throttle response once it is in gear?
is the piece on the back of the block where the distributor would be that one of the vacuum lines go to need to be adjusted (it got turned when i was removing the intake manifold)?
why do i still have the "white diesel smoke"?
any suggestions will be greatly appreciated. again thank you.
-oil change
-new air filter
