APOC's singled and ready to plunder n pilidge!
gimpyrobb
dumpsterlandingfromorbit!
27,786
770
Cincy Ohio
I just mounted the same tires. Other than the size and weight, they went on just fine. I set the rim on a bucket, dropped the tire on the rim, pushed the valve stem in, put on lock ring, and aired it up. Just like with the 900x20s, it would seat over the lock ring at about 30 psi. Any thing else you want to know?
IHASFIP
TEXAS
No that is it I guess. I just figured you would have to compress the tire alot to be able to get the split ring on there.
D
