Are the M818 12volts or 24volts?
Hooty481
Russell County Kentucky
are all of the M818 12volts or 24 volts. I have seen where people where having to convert the 24 volt traielr light to 12 volts for civy trailers but the truck i just bought from GL says that it is 12 volts when you click on the nsn number at the bottom. it says 4 batteries but 12 volts. did they change them over or maybe a miss print.
Capt.Marion
15
Atlanta, GA
Two sets of 2x 12V batteries wired in series gives you essentially 2x 24V batteries. Wiring those two sets in parallel with each other gives you one 24V power supply that can source twice the current.
