Are we sure the .mil used only DOT5 in brake systems?
4bogginchevys
rathdrum idaho
I may not be answering your question, i'm sure the guys using these trucks had to settle for something different than the specified dot 5 from time to time, and I bet anything will work if not mixed improperly (dot 3,4,5,syn,non syn...):-D
4bogginchevys
rathdrum idaho
if I read this right.....you cant tell the difference. I do agree with the TM's on the syn recommendation.....it's all about base ingridients and how they react to/control heat.....you might have to be more specific...:-D
Csm Davis
382
Hattiesburg, Mississippi
it doesn't matter what was in it when you got it you should drain it all out and start with fresh new fluid in every system on the truck because is you life or someone else's or even you truck not worth a couple hundred dollars?:oops:
1,176
Read the WORDS STAMPED into the master-cylinder cover. It clearly says to use DOT5 only.
You can test to determine if you have dot3 or 5. It has been discussed many times. Search the forums!
One link with the basics. http://www.steelsoldiers.com/369672-post3.html
