Overdrive
- 94
- 28
- Wentzville, Missouri
I don't believe this has been posted before. I was searching around my troubleshooting folder and I have a couple of images from the Army PM Magazine (the cartoon tips magazine) articles for the LMTV so I thought why not try to see if they are online and if they have an index for FMTVs... Yes and yes
Website (For some it throws up a privacy warning concerning the certificate. Worked without warning on my desktop but my cell phone had the warning so I choose the option to go there anyway):
https://www.logsa.army.mil/psmag/psonline.cfm
Not sure if this will all post but I looked through their index of all articles and these are the ones for FMTV with the subject, issue number, and page number.
Hope this is helpful (the misspelled words in the list are strait from the Army index)
TRUCK, FMTV
SUBJECT - ISSUE - PAGE
5-Tonner--Brake caging 559 4
Air dryer canister nut 544 61
Air dryer servicing 580 3
Air dryer servicing 628 11
Air pressure buzzer 575 61
Air tank draining 629 7
Air/hydraulic fluid restrictor cleaning 571 6
Air/hydraulic power unit leak 539 3
Air/hydraulic unit vent mist 569 2
Alternator bracket for 100-amp alternator 553 8
Auxiliary oil cooler guard 559 2
Battery cable moved to protect cover 567 2
Battery tester 547 8
Battery wiring diagram 562 3
Brake spider 582 12
C6 transfer--Bolt installation, torque 589 60
Cab air bag inflation 562 2
Cab air springs use 625 16
Cab and suspension hydraulics 586 6
Cab cleaning 606 13
Cab floor drain plugs 574 3
Cab hydraulic cylinder lubing 577 6
Cab leveling linkage check 567 3
Cab lifting with add-on armor 635 14
Cab lowering method 559 3
Cab raising technique 537 21
Cab raising, lowering 583 10
Camo paint patterns 572 61
Cargo bed D-ring lube 597 3
Cargo cover and component NSNs 633 10
Cargo cover repair kit 604 61
Circuit breaker 35 correction 571 61
Circuit breaker identification 561 8
Circuit breaker resetting, checks 605 7
Cold engine starting 601 12
Cold starting 601 12
Cold weather PM tips 636 21
Convex mirrors 581 6
Coolant overflow tube 554 6
Cooling cautions 608 12
Crane cable clevis clamp 595 61
Crane clevis clamp 595 61
Desert cover NSNs 564 61
Desert maintenance 608 14
Desert tan covers 616 60
Desert tan covers 560 61
Door damage from cab raising 610 11
Door handle not handhold 588 6
Door seal relocation 578 5
Door, window handle tightening 566 7
Driveshaft bolts 574 4
Driveshaft end cap bolts 593 8
Fan shroud differences 598 4
Fifth wheel forward to pull trailer 583 9
Flat towing instructions 589 60
FMTV introduction 526 27
Footholds to avoid 574 2
Front shock bushings 589 6
Fuel system water draining 568 6
Fuel tank draining 611 10
Fuel-water separator care 568 6
Fuse links at alternator removed 569 3
GAA NSNs 624 61
Gladhand vent check 584 5
Hand throttle not cruise control 606 12
Hand throttle use 529 6
Headlamp change 531 61
Headlight 528 61
Headlight lamp 558 61
Heater controls 554 6
Heater switch fire hazard 580 2
Hydraulic fluid 573 61
Hydraulic fluid authorized 594 61
Hydraulic fluids for power unit, crane, winch 596 5
Hydraulic manifold knob lube 546 9
Hydraulic pump use 602 5
Hydraulic pump valves 555 2
Hydraulic system use 537 20
Input seal warranty 629 5
Light problem solutions 560 5
M1089 wrecker main winch cable tension 552 8
M1089A1 wrecker--Component list on EM 0195 629 5
M1093/M1094 davit PMCS 536 3
M66 machine gun ring mount 578 6
M66 ring mount cover 627 13
Machine gun mounting 591 5
Machine gun mounting kit is DS/GS 536 60
Micrometer for wheel bearings 536 2
Mud flaps in off-road operations 552 9
Oil pressure indications 609 5
Paint camo patterns 627 61
Parts--Use TM, not local purchase 637 13
Radiator cover for cold 556 2
Radio installation kits 550 3
Ring mount cover NSN 626 8
Ring mount support 550 3
S-280 shelter tiedown kit pins 603 13
Seat covers 575 61
Seat handle motion 553 8
Shelter ladder kit 598 61
Shelter tiedown kit 549 61
Soft top canvas support 562 3
Speedomenter switch setting correction 564 61
Speedometer switch setting -- See correction 559 4
Speedometer switch setting correction 564 61
Steering wheel chain 556 3
Steering wheel security 586 7
Tailgate rivets 573 8
Tire chain use 591 60
Tire chains 553 8
Tires from a new supplier 570 61
TM corrections 548 7
TPU tiedown kits 545 5
Trailer for general cargo, ammo only 591 60
Trailer use restrictions 590 61
Tranmission draining aid 577 5
Transmission capacities 536 2
Transmission drain plug check 566 6
Transmission electronic control unit 566 7
Transmission oil change interval 545 10
Transmission oil filters 566 5
Transmission oil level check 629 4
Transmission oil update 544 61
Transmission oil, level check 541 9
Troop carrying capacity 590 61
Troop seat damage 545 5
Troop seat strap 629 6
Troop seat strap replacement 550 4
Troop-carrying capacity 590 61
Van--Air conditioner kit 587 5
Vehicle bridge classification numbers 550 2
Volcano mounting authorized for M1090 587 60
Volcano--FMTV mounting 578 61
Winch cable winding speed 577 7
Winch control switch settings 585 2
Winch reeling in 609 4
Winch switches prevent battery drain 558 6
Wiper arm shaft nut 588 7
Wiper blade refills 550 61
Wiper refills 546 61
Woodland camo cargo covers 581 6
TRUCK, FMTV
Brake spider 582 12
Cab cleaning 606 13
GAA NSNs 624 61
Headlight 528 61
Seat covers 575 61
Tire chains 553 8
