Arrival of 2nd HMMWV M1151A1
Gcelevator
803
Fort Lauderdale, Florida USA
Gcelevator
803
Hey guys, ia m back with questions. I have this selenoid or ?????? ( Not sure what it is) and i can not d
Find it in the TM's. Wires are marked 785B(which in the wire tags list shows as OFSA large fire signal) not sire what it is and 458 which is the engine fan clutch circuit. The fan clutch is engage the whole time but i would like to identify the function of this part and how it is related to the engine ( i am lost here to be honest) this is for the M1114 engine and parts donor.
Gcelevator
803
According to this 458 is part of the fan clutch circuit, but I am too tired to look at the schematics, what do your schematics say?
Yes, exactly the same. I am at lost on the other wire connected. I need to check the schematics as i did not check into it. I was looking for the fan clutch components to try and identify the selenoid (or whatever part thet is)
Milcommoguy
2,414
Rosamond, CA
That part is a circuit breaker. Don't normally see a breaker in that circuit. Trace it out....
Always something new, CAMO
Gcelevator
803
It looked to me like a Bimetal or temperature breaker as you said. I will try and follow it or look in the circuit where the other wires are supposed to go. Probably someone at the yard just placed it there for fun.
Mogman
10,530
Papalote, TX
458 carries 24V from the "RUN" circuit to the fan thermal switch to the TDM, I don't see a 700 anything on the schematics, certainly does not mean it's not there though.
Mogman
10,530
Papalote, TX
What is strange is at that point 458 normally would be terminating into a molded plug for the TDM
Retiredwarhorses
4,606
Brentwood, Calif
the wire on The wire harness is the power feed to the circuit breaker used to power the Milemarker winch…
Gcelevator
803
Thank you Steve, i had something in mind as the selenoids are right there but in the wire codes list it shows as something fire and i was at lost on that one. Do you happen to know where i can find a diagram for that section? As my fan clutch is engages the whole time. Also, any place i can obtain that part? Are the ones under the dash the same specs?
Thanks again. 👍
Gcelevator
803
Well guys, back at it after a long time. I had to clear the back yard and started working on the 1151 (i have been posting pictures on the whst have you done thread)
I started like 3 weeks ago or so, removed the cooling stack and engine from the 1114, installed on the 1151, and so on. Every step when possible, i was starting the engine to make sure everyting was falling in place as intended. Engine sounds good and starts amazingly well with only one issue, i had forgotten that the fan clutch does not disengage and might be damaged.
This weekend i was fitting the doors and all seems good except for one door, the brackets inside are destroyed. Trying to source that extruded aluminum profile to no available, if i can't find it, i will replicate in stainless steel.
Here are some pictures of the almost done truck.
Gcelevator
803
I need this AC conduit under the A pilar by the turbo. When i look for the part number (at HPG) it says is discontinued and then redirects me to the part for the non Turbo. I would say the non turbo part will not fit here, i might be wrong.
Mainsail
1,804
Puget Sound, WA
Trust me, you don't.
The install is a major PITA and after you're done, get ready for disappointment. Even with every single louver closed, the amount of air expelled through that one by the driver's knee is imperceptible.
Just cap them off at each end and get on with your life.
Gcelevator
803
Thanks for the advise, i had this in my mind but on my M1123 it gets hot down by the knees (no tunnel outer insulation) i will probably end doing it, capping off the vents.
