rustystud
- 2,779
- 113
- Woodinville, Washington
![056.jpg 056.jpg](https://www.steelsoldiers.com/data/attachments/350/350587-69ecface17409703891e48a33086ddcc.jpg)
![058.jpg 058.jpg](https://www.steelsoldiers.com/data/attachments/350/350588-efaa71f38e512ad1b9c7534765674870.jpg)
![060.jpg 060.jpg](https://www.steelsoldiers.com/data/attachments/350/350589-3d0d6cbaac6dd55f338730b71eaac7a2.jpg)
![062.jpg 062.jpg](https://www.steelsoldiers.com/data/attachments/350/350590-0747394bc08a16444ae33917e4631d92.jpg)
![063.jpg 063.jpg](https://www.steelsoldiers.com/data/attachments/350/350591-7d6611f2d426c169c127ed46807e7c47.jpg)
![064.jpg 064.jpg](https://www.steelsoldiers.com/data/attachments/350/350592-37a7f11b8222db30e51a14c6505e1269.jpg)
![065.jpg 065.jpg](https://www.steelsoldiers.com/data/attachments/350/350593-672200666d7b4fb1ef24faa581cb611a.jpg)
![066.jpg 066.jpg](https://www.steelsoldiers.com/data/attachments/350/350594-011ca5451ae947e8fc64ea2f61c1dacd.jpg)
![067.jpg 067.jpg](https://www.steelsoldiers.com/data/attachments/350/350595-f1fae073bc52f5fab5665d53f52a6bea.jpg)
![068.jpg 068.jpg](https://www.steelsoldiers.com/data/attachments/350/350596-f35ba14916ce275803c8b4dfb48abb63.jpg)
Yes, if you don't get a good straight cut on the hose sometimes you need to use a knife to clean it up. On the aluminum fittings I use anti-sieze, but I'm sure motor oil will work OK .1 thing I can add is that after cutting the line, I suggest deburring the edge of the teflon with a razor knife. It allows the Ferrule (olive) to seat better on the end of the line.
They also make aluminum hose ends. If using these I recommend motor oil on the threads to prevent galling.
Good looking engine you have there Neophyte .Awesome write up!! I used a the same hose for fuel lines on a DD453 I rebuilt over the winter. The critical part was cutting the braided hose with a fiber cut off wheel (took a couple tries to figure out that was the best method). Once the braid comes undone.....impossible to connect the compression fitting on.
They are the "cats meow ! " I see you used the aluminum fittings. I always just use the steel ones, that way I can recycle them to use on hydraulic systems if I need to.Thank you. I wish this write up was available 6 months ago.......I must of cut the braided hose 4 times before getting it right. I used 8an fittings throughout the fuel system...worked like a charm. These PTFE hoses are a huge step up from the old rubber hoses.
