Auctions observations
hwcurtice
35
Moncks Corner, SC
So, I'm looking at the various large trucks that are being auctioned off on GL, wish they would do some in Washington, but I notice that most, if not all, have either a pallet or a drip pan under them.
Does this concern you, if it has a drip pan, or make you feel better, if there is a wooden pallet under them? I'm guessing the wooden pallet is for moving them with a forklift and trying, yes trying, not to damage the vehicle while doing so.
Of course, those with flat tires worry me. Those with what looks like fluid leaks coming of the hubs worry me too. The ones with missing engines, well....
gunboy1656
22
Beaver Falls, PA
Drip pan is not a real worry as most of the times it is a military requirement to put a drip pan down. Never really figured out the pallet thing, but I would assume it was for a similar reason.
Seeing the fork damage, I doubt they take the time to lift using a pallet.
Oh, and I have never see an MV that didn't leak, unless it was out of fluid.
jhooah
Carrollton/Virginia
Perhaps: Put a pallet down to stick the drip pan on, easier than bending down to crawl under there, etc for a guy riding a forklift. Then he only has to remove the pallet as he's riding by later...
WAW
wiggall
151
Lenore, Id.
Ft. Lewis will have a few 5 tons go through, but the 2.5 tons were perty much moved through in 08. One will show up once in a while, but they are mostly parts trucks.
SETOYOTA
450
georgia
It is a requirement to have the drip pan. The funny thing to me is the pans are actually baking pans.
mcmullag
13
Colorado Springs, CO region
not daily drivers
It's a guv-mint thang, those drip pans and pallets. If you are lucky, in warm weather, the trucks don't leak as much, also if you run them regularily, they seem to not leak and drip as much. Seems like all the gaskets and seals harden up or are dry and not sealing in the best way because the trucks sit idle so much of the time.
rchalmers3
30
Irmo, South Carolina
I guess some of these babies are still in diapers.
The last truck I picked up both leaked from the crank seals and was drained. Hows that for being determined?
Rick
DieselBob
15
Arnold Maryland
Kind of like radial engines. If it doesn't leak there is something wrong with it. Although my deuce doesn't leak much but I haven't put many miles on it yet.
41cl8m5
36
Littleton, CO
I saw a GL worker move a truck with a fork truck. Having the palet under the front axle of the truck is, I guess convenant. Always wondered why there were no chalks and the brakes were off. Of course the GL lots I have seen are mostly level
popacom
9
winchester,ky
The DRMO guys were about as hard on driveshafts as the GL crews are,used to
make me sick to my stomach . LOLaua popacom / BILL in KY.:cookoo:
