Automatic transmission temperature
cranetruck
75
Meadows of Dan, Virginia
My xm757 comes with a "dummy" light for transmission overheat warning and I'd like to replace it with a gauge.
A "transmission temp" gauge has a 160 to 320 °F range from what I understand, but I would rather use a regular MS24543-2 coolant temp gauge with a 120 to 240 range for better resolution and I already have a sending unit for it...
Question, how often would the temp get above 240? (The warning indicator is set for 305°F).
TIA
juanprado
2,829
Metairie/La (N'awlins)
in the m939 series the trans temp sender is the same part # as the water temp sender. Different gauges but the sender is the same nsn for each gauge.
juanprado
2,829
No because the sending unit works the same way. It doesn't know oil or water just temp and converts it to an electric signal to the gauge. I am sure the electrical folks can explain the resistance thing on how it specifically works.
Same thing for civilian gauges I use to sell at NAPA that were vdo or stewart warner. I think stewart warner is who makes the military gauges.
162tcat
45
Washington
Location of the trans sending unit on the m939?
Sent from my SM-G950U using Tapatalk
Easy there bud, one post is more than enough. You can also download the Technical Manuals or "TMs" as they are often referred to. Multiple posts on the same question are not helpful and just clutter things up.
TEAMJENSEN
NJ
I was able to find with your help the sending unit and now have the transmission temp reading correctly. I appreciate the help and the picture was very helpful.
