jsutherland
- 6
- 3
- Valleyford, WA
Looking for input and clarification. I am installing auxiliary LED back up lights on the rear of my 86 M1008. The lights are 16 watts a piece and I am planning on running two off the rear bumper. My questions... Can I splice straight into the existing back up light wires? My lights say they are 16 watt lights. Using a conversion calculator it says that they are about 1.33 amps a piece. I know the existing back up light fuse on the CUCV says its a 30 amp and should have no problem holding the additional amperage if my math is right. Does this sound correct to anyone that knows more about it than me? Also, is the existing back up light wires the best place or should I look to wire into the trailer harness? I am trying to wire these directly into the back up lights so they are not on a switch but come on only in reverse. Thank for the help.
