Thanks!Nice! Can you spray fake CARC that nice? I may have found me a paint shop.![]()
I've never sprayed Carc, but I imagine it isn't too bad to work with.
I need to let the paint harden up over the next few days, then I'll be cutting and buffing it.
Seems like you either need to use lighter grit and sand a little less OR paint thicker coats.Had a little whoopsie while buffing the hood. Burned the clear a little, right smack dab in the middle of the hood. Not a huge deal, just gotta sand it back and blend in some color.
View attachment 921731View attachment 921732View attachment 921733
The beauty of the clear coat system!Had a little whoopsie while buffing the hood. Burned the clear a little, right smack dab in the middle of the hood. Not a huge deal, just gotta sand it back and blend in some color.
I was in an awkward spot with the buffer, and stood it too much on its edge and burned the clear real good. Getting to the center of the hood on these things isn't as easy as you'd think lolSeems like you either need to use lighter grit and sand a little less OR paint thicker coats.
Been there. Done that.
The hood says NO STEP...Hood is fixed, and custom made decals installed. Had someone reproduce the original markings in satin black. They blend in nicely, but are still visible.
And the major question is… Why do you have an overhead garage fan in Massachusetts?Hood is fixed, and custom made decals installed. Had someone reproduce the original markings in satin black. They blend in nicely, but are still visible.
Because for about 3 weeks in the summer it is unbearable!!!!!And the major question is… Why do you have an overhead garage fan in Massachusetts?
I mostly use it to circulate the heat in the winter time. I have 12ft ceilings, and a lot of heat gets trapped up there.And the major question is… Why do you have an overhead garage fan in Massachusetts?
