Axle fluid plug/Transfer case plug hex? Where's brake fliud
wsucougarx
65
Washington State
I went and checked out some deuces. Everything was going great with some trucks and others not so great. I brought a 1/2" drive with me. Now I couldn't gain access to some axles and transfer case b/c of a hex type of plug. Can anyone tell me what size I would need? Now hopefully memory serves me correctly it looked like an octagon hex type plug?
Also, where in the world do I look for the brake fliud reservoir? I assume it's not in an obvious site and probably doesn't have an easy to read fluid reservoir like our cars. When I looked under plate on the driver side I didn't see a distinct reservoir just a couple metal apparatuses. HELP
1,331
decatur alabama
Re: Axle fluid plug/Transfer case plug hex? Where's brake f
Thats it. you open that little plate on the driverside floor board and see the cap and the breather line on the brake system. Thats it. most people add a regular reservoir
m16ty
228
Dickson,TN
gringeltaube said:
Try a 9/16" hex type wrench.
Never saw any octagonal plugs.
G.
I'd say it takes a "allen" type wrench. You may be right on the size. I can't remember.
gringeltaube
Staff Member
2,690
Montevideo/Uruguay
:) First I had put "allen" wrench ... but wasn't sure if everybody was familiar with that...
So Yes, it's a 9/16 allen! Only found those as drain plugs in a few trannys and MF fuel tanks, never on TC or axles.
m16ty
228
Dickson,TN
Allen is actually a brand name but everybody around here calls them "allen wrenches" :wink: .
neilhendrix
Reidsville N.C.
LOL Just kidding ,,I have Allens/Hex up to 1" I used everyday before I retired . probably got 100 , maybe the scrap ward ,,right much weight there,
Barrman
2,191
Giddings, Texas
If you find yourself in a spot where you don't have a 9/16" Hex or Allen. Grab any 3/8" bolt which has a 9/16" head on it. Use two nuts jambed together on the bolt to turn it with a regular 9/16" wrench. Vice Grips work good as well. So does welding a nut onto the bolt.
Buying the proper tools is the best route, but on the side of the highway you use what you have.
