axle maintenance
nattieleather
144
Cleveland, OH
Hi all,
I have a set of 70 dodge axles the same as the M880 serries trucks and I'm looking for the section out of the -20 and -34 for the maintenance of the axles. I did a search through the manual here, but didn't find them. I don't need the whole manual just the section on the front and rear axles.
Does anyone have them in electronic form that you could e-mail to me?
Joe
gringeltaube
Staff Member
2,521
Montevideo/Uruguay
I found at least these two listed in the TM section, to download:
TM 9-2320-266-24P Direct Support and General Support Repair Parts and Special Tools List, M880 series
TM 9-2320-266-34 Direct and General Support Maintenance Manual, M880 series
Included should be what you are looking for...:roll:
G.
nattieleather
144
Cleveland, OH
Thanks I must be going blind in my old age... :) That's exactly what I was looking for. Now I won't be working off the cuff....just blind...lol~!
nattieleather
144
Cleveland, OH
Ok one more thing...the -34 states to remove the axle shafts go to TM9-2320-266-20. In other words that is a orginizational maintence item so you have to go to that manual even though you at direct support. Go figure. Anyone know where I can find the -20?
1,808
Bob H
161
I'll see if I can scan my service manual for the front
the rears - pull the 8 bolts, slide the axle out, then you will have jam nut w/lock tab that holds brake drum/wheel bearings on.
Also you may find something on ramchargercentral.com or powerwagonadvertiser.com
