axle seal part numbers
helsel182
palm bay fl
i am looking to replace the axle seals on the rear because they are leaking but i cant seen to find the part numbers does anyone know what they are? thanks in advance and thanks for the add just bought my first deuce this weekend 1967 m35a2 love the thing so far.
silverstate55
Unemployable
2,125
1,078
UT
The seals on the hub ends or the input/output pinions (where the driveshafts connect)?
The outer hub end seals are part #7061238, NSN 5330-00-706-1238. Inner hub end seals are part #10896684, NSN 5330-00-891-7826 (replaces part numbers 7521649, A1205Z650, 630D6, A298451, 913842, Q1205Z650; also used on 2.5 ton truck rear suspension pivot).
The input/output pinion seals (where driveshafts connect) are part #7521241, NSN 5330-00-143-8666 (alternate part numbers 12470104, A-1205-U-515). Also used in 3 locations on transfer case.
Can be purchased where fsearls92 linked to.
