Mike82ndABN
- 10
- 18
- Tampa/Florida
I have noticed that I get a little oily fluid under my truck, which I have traced back up to the air cleaner dump valve, and confirmed a little of it inside the air cleaner housing.
The fluid isn't ATF (thankfully), it is a clear-ish brown fluid. I had been thinking that it could be power steering or brake fluid from a vent line (not sure if this happens with the vampire).
I was researching valve cover leaks and came across some info about the CDR allowing excessive pressure if it goes bad (stuck closed), and one of the symptoms of a bad CDR (stuck open) was finding engine oil deposited in the intake and air cleaner from the fine mist.
I am beginning to think this fluid may be engine oil, I only get a few drops here and there so it is hard to figure out what exactly it is but it is oily and it is not red.
Does anyone have an input? Thanks. I may change it out as preventative maintenance.
