bad mep002a rotor
yeehaa
Austin TX
I was replacing the rotating diodes today. While I had them off I went ahead and checked the coil resistance and coil to coil resistance, and all 3 are shorted together.
Does anybody know how much it will cost to have the rotor re-wound?
Speddmon
Blind squirrel rehabiltator
32
Cambridge, Ohio
They may not be shorted together. The coils are going to be pretty low resistance, and if you forgot to disconnect the plug going to the AC output box the coils would have been connected together via the L0 connection. You would need a good low resistance meter and the specs/test procedure from the TM to make sure they are truly shorted
PeterD
Jaffrey, NH
Yes, what coils did you measure? The ones in the rotor (input), or the stator (output)? As Speddmon mentions, they are difficult to measure the resistance of. Only easy test is for shorts to ground (all windings are isolated with respect to ground, but you still have to follow the exact procedures in order to make the measurements.
yeehaa
Austin TX
I'm a dumbass. When I broke out the 5-6115-584-34 it shows them wired together in figure 8-2.
These are the exciter coils on the rotor.
Thanks for the answers.
