Bad Paint job
LeutDan
Boone, NC
Hey guys,
I am here to ask some advice on painting with a rattle can. I just sanded/ primed/ sprayed my m1009 with 15 cans of spray paint (not including primer). I used the Krylon OD green (part of the krylon camo colors). I am fortunate enough to be able to use a family member's huge warehouse so I did it inside and I am seeing spray lines from the can. I have tried to overlap 1/2 and 3/4 and even just barely overlap with no good results. This is my first time painting so I am looking for some tips/tricks for a close to even paint job.
Thanks!
jeep-Jeep
Liberty Hill Texas
The krylon has a tip that is hard to fan on to blend correctly .
you can get a carc substitute from rapco and it comes with 2 different type of tips per can .
it is comparable in cost before shipping .
REGULATOR
Martinez GA
hate to sound vague, but search onthe internet for how to spray paint,
I've found several really good tips and techniques.
its one of those things that once you develop the right technique it seems easy, but it can also be easy to mess up.
the right paint helps, as well as all the other factors such as temp and prep and how you spray. how close you are to it, how much paint you use and how soon you apply additional coats.
be patient..
roscoe
Spencerville, Indiana
Its going to be difficult to get it even when you are painting one color with spray cans. Its a lot easier if you go with a camo pattern. If you want it to look really good, I'd use on of the regular auto type spray guns. Another thing to consider - if you buy the paint - you can probably get a auto body tech school to spray it for a tip.
LeutDan
Boone, NC
hey man i can paint it for you with professinal auto body paint for ab about 850
Thanks for the offer but I am only painting it to learn a little. It is just a toy for me right now so it is not really important. If I ever decide to get a real paint job I will look ya up though. A gloss O.D. green would be pretty sweet!
bryan70546
Lake Charles La
