bad turbo?
schnackj
Escalon CA
What do you guys think, Its hard to tell but it seems like there may be a crack on the side of the housing, I can feel hot air coming from somewhere and some oil is coming out near its connection to the exhaust. I just found it today so I haven't had a chance to look into in further.
This is a non whistler on a late AF truck.
gimpyrobb
dumpsterlandingfromorbit!
27,785
748
Cincy Ohio
At the very LEAST your missing a clamp on the exhaust. You need to look into what you have, and should have.
schnackj
Escalon CA
I'm running a fairly high oil mix right now. I'm going to pull it apart tomorrow morning and see what it looks like since it doesn't seem right.
There is supposed to be 2 clamps on the exhaust then?
rosco
Delta Junction, Alaska
Lets see - I once lost a turbo. The bushings failed, lost clearance & the vanes started contacting the housing. The danger is that it sheds vanes on the intake side and they get into the combustion cylinders. In the mean time with the lost clearance, on the combustion air side, It began consuming vast quantities of lube oil. About a gallon per mile.
Yours looks like the clamp is off, its running slow & cold (slobbering), and is way too rich.
KsM715
142
St George Ks
There is also the danger of bad seals and sucking in oil on the intake side and having a run away motor
gimpyrobb
27,785
748
Cincy Ohio
Pic didn't show on my cell as well as it does on the PC. I was mistaken, no clamp missing. Some of these motors have an adapter there to fit them to the exhaust(on a 5ton truck) which is what I thought I saw.
schnackj
Escalon CA
Ok i was able to get the exhaust side apart and take a look at thing, there is definitely no crack, there was just some flakey rust wedged in near the clamp. but it seems like there is a lot of oil in the first exhaust piece after the turbo and the flex pipe.
do you guys think this may just be un-burnt wmo in the fuel or a bad seal in the turbo?
I cleaned up the flanges and gasket and put it back together and ran it again and I don't feel any exhaust leaks in the area.
WillWagner
2,454
Monrovia, Ca.
Unless you have been idling it or not taking it out and running it hard. The multi likes to be run hard and hates idle time.
schnackj
Escalon CA
well I'm almost sure its slobber as its been sitting in the same spot only idling for a while while I have been working on a few things on it and needing air. However in my panic yesterday I put a bid in for a NOS replacement turbo and ended up winning it today for around 260 shipped. So I think to be safe I'll put the replacement in and keep the old as a spare, Is there a recommended procedure for pre-lubing a fresh turbo before start up.
