chicklin
- 0
- 0
- Kansas City, MO
Will the truck run if the turbo is bad (i.e. inoperable)? I'm looking at one that has a bad turbo and just need to limp it home.
Tow it. There is no other safe way.What is the best and safest way to just disable it until I can get home and troubleshoot.
If it is just siezed, Leave it in place and drive her home. No need to pull (and plug) the oil line. It will run fine, just a little restricted. I think Stretch told me his turbo was siezed initially and it freed up on the drive home. Ken and Jwaller can rebuild your turbo for ya.
I get what you're saying, but there's got to be a way to get the thing home without the turbo. Not every multifuel had a turbo, anyway. Can't I just take the darn thing off and put in a temporary flex pipe from the air cleaner to the intake? There would also be an oil line to deal with, right? Can I just cap it off?If the turbo wasn't in perfect shape I wouldn't drive it. If you've ever seen a engine that has ate the compressor vanes or run away you'll know why.
