BAMBULANCE progress
sermis
17
Temple, TX
Ambulance cool
Ambulance transformation in progress. Truck is preped. Need a way to lift and set it on the truck.
Anybody know where to get the rubber seal for the windshield and bulkhead?
Sent from my SM-G920V using Tapatalk
AAVP7
262
Dortmund, Germany
Now that´s a familiar sight ! I also dragged my ambulance top home on a trailer.... ;-)
For lifting: There are four bolt points at the top sides where eyelets could be put in, but I seriously doubt that they will carry the 2,000 pounds of the top. The eyelets were intended to hold straps that would keep the airlift spreader from falling down.
I didn´t use those eyelet options.
I lifted my top with four chain hoists. Each with a 2,000 pound capacity, so there was a bit of safety margin, and hooked all four hoists on slings hanging from my garage´s roof beams. I did some quick calculations before, though. The load of the top was about equal to the snow load that the roof needs to carry in winter. At the bottom, I used two long double slings run under the main body. One at the front where the bulkhead gives a lot of strength to the body, and one right at the begin of the overhang.
No idea about the seal. My top came with that seal in "still OK"-condition, but I think I could well use a new one. If you find a source, woulkd be great to hear.
papakb
1,185
San Jose, Ca
When I dropped my 996 body on 18 years ago we ran chains diagonally from the lifting bolts build into the body (on the sloping panels) with a forklift No problem at all. What we did was to lift the body straight up and then back the truck under it and lower it down.
5 bolts and 2 wires later the job was finished. You will need to pick up some 18" extensions for the taillight wiring because they relocate to the rear body panel. Then I mounted a backup camera on the rear crossmember under the body. It shades it a little bit but you can still clearly see what's behind you and the kids don't play with it in that location. Ran my backup light power from the shifter legend lights. That way I could leave the dash lights off if I didn't want them to come on and it's a convenient place to pick up light power.
I'm still looking for another litter rack access door to mount to the right of the stairs if you know where a damaged body is that one could be salvaged from.
AAVP7
262
Dortmund, Germany
Funny coincidence, my litter rack access door is there, but it is missing it´s lock..... And I haven´t found a replacement yet.
But that´s very interesting to hear that you lifted the body by those lifting bolts. How much weighs an M996 body ? The bolts themselves should be sturdy enough; I think they were like 1/2" or something. But I was worried about their sockets inside the aluminium honeycomb shell.
We need a Humvee Ambulance Owners Group here for sure..... :mrgreen:
Wire Fox
161
Indianapolis, Indiana
Is the seal you're looking for Item #6 in the picture? If so, that's NSN 5330-01-197-8298 / PN 12339594. MacMotors has 3 in stock and they're about $24 each.
Wire Fox
161
And here I go again. Are you talking about Item 2 in this picture? If so, that's NSN 5340-01-260-9942 / PN 12341705. Once more, MacMotors has this for $32. EDIT: Whoops, Mac's actually out of stock. You can request it from them, if you'd like. As well, HPG lists the part, but it's special request only. Shoot them an email and they may be able to help. https://www.hummerpartsguy.com/LATCH-LITTER-STOWAGE-DOOR_p_18622.html
Before any says anything... Sorry papakb, I didn't see any hits at MacMotors for that door or the full assembly.
AAVP7
262
Dortmund, Germany
Wow, you´re great help, Wirefox. I didn´t have MacMotors on my radar when searching. Bummer I just had an order shipped from HPG. But I´ll ask them. Thanks very much, Wirefox !
papakb
1,185
San Jose, Ca
The original latch is just a standard Southco draw latch. I used an aircraft latch I had around because it fits flush.
sermis
17
Temple, TX
6 That's the one I need along with 4 & 5
M813rc
3,192
Near Austin, Texas
Steve, your pictures come up as links to those of us on computers (I don't know if phones automatically show them?) so for posterity and us less "mobile" types, I'll add your pictures here. ;)
I see you got it installed pretty quick, looks great!
Cheers
papakb
1,185
San Jose, Ca
I did a search for "military wiring extension" and the short harness you need to relocate the taillights comes up.
Wire Fox
161
I received a PM asking about more part numbers, so I'm just going to post the rest of the list from that TM here:
1 PAFZZ 5320012716357 9K475 MGLP-B6-4 RIVET,BLIND WHEELHOUSE SEAL,3/16... 14
UOC:A15,B15,B16,H15,H16
2 PAHZZ 5340012902265 34623 5598163 BRACKET,ANGLE....................... 2
3 PAFZZ 5330012727473 34623 5589947 GASKET.............................. 2
4 PAFZZ 2510012709447 34623 5585446 EXTENSION,WINDSHIEL R.H............ 1
5 PAFZZ 2590012709446 34623 5585445 BRACKET,VEHICULAR C L.H............ 1
6 PAFZZ 5330011978298 06968 ORD-112 SEAL................................ 1
7 PAFZZ 5310008095998 96906 MS27183-18 WASHER,FLAT 1/2.................... 2
8 PAFZZ 5305000712071 80204 B1821BH050C200N SCREW,CAP,HEXAGON H 1/2-13 X 2.00.. 2
9 PAOZZ 5320012645978 19207 12339355-2 RIVET,BLIND 3/16................... 42
10 PAOZZ 5310008807744 96906 MS51967-5 NUT,PLAIN,HEXAGON 5/16-18.......... 4
11 PAOZZ 5340012893245 34623 5598904 BRACKET,MOUNTING.................... 2
12 PAOZZ 5342012897708 70655 4375 BUMPER,SPECIAL...................... 2
13 PAOZZ 5310008095998 96906 MS27183-18 WASHER,FLAT 5/16........ 2
(For those not familiar with the manuals, the first number is the part reference to match to the picture. The five-letter code is the SMR code. The 13-digit number is the NSN without hyphens (very useful for looking up part that is made by multiple companies). The next five-digit number is the Cage Code, which refers to a specific manufacturer. The next alpha-numeric number is the part number that's associated with that specific manufacturer. There's then a description of the part, finally followed by the quantity of that part used in the assembly.
The UOC list below each part is the "Use On Code", which list what vehicle codes this part applies to. There's a chart at the beginning of the TM to list what each vehicle configuration would be, then you would know which parts throughout the manual apply to your specific vehicle.)
skaz76
Pittsburgh Pa
Not to hijack the thread but ditto on the ambulance owners group! I put a 996 top on mine a few weeks ago, it was interesting doing it by myself but got it done......move an inch check everything, move another inch......took all day but went on without issue or injury. (and believe me the neighborhood audience was on hand to watch the crazy redneck doing ...well the stupid stuff i do) As to the 4 mounting holes on the side.....wouldnt trust them with 1500 ish pounds over my head, so i went with the jeep winch and a bunch of racket straps....and wood. and btw... the tractor was there to hold it up long enough for me to get out of the way if it let loose....so i didn't20191018_123143.jpg20191102_170628.jpg20191103_163053.jpg20191103_170528.jpg20191109_143309.jpg20191109_165053.jpg cheat.
papakb
1,185
San Jose, Ca
That place looks exactly like Jim Williams yard in Scranton where I got all the little bits and pieces mine was missing!
Rcco
MI
Working on a M996 project myself, thank you for some great info.....question, what is the best way to lift one? Are the 2 bolts one each side the lift points?
Thank you
papakb
1,185
San Jose, Ca
When I got my 996 body from Naval Station Brunswick (Maine) it came with the hard doors, intercom system, litter ramp and the correct spreader bar for lifting the body. It attached to those 4 bolts on the sloping sutface on the roof and the sockets go directly into the frame so it's where AMG lifted it so that was good enough for me. Since then I've mounted 2, 8' sections of 1" unistrut to them that allows me to attach display panels and sun shades to the body easily. No one seems to realize that they aren't part of the original kit.
Somewhere I have the original latch and if you still need one drop me a PM and I'll send it to you if I can find it. I went with a flush aircraft latch because surprisingly people can't figure out how to open it and it keeps out the curious.
Since I've mounted the ambulance body I've looked for another litter access door to mount on the other side and even though I've found a couple of bodies being scrapped I have yet to get a second door assembly. Anybody know of one languishing in a scrap yard anywhere?
Another thing I pondered over was how to secure the rear doors. I came up with the Yale lock on a trip over to England and it works perfectly:
This P-89 latch has a tapered brass lock section, their P-82 has a squared off end. In the UK it's referred to as a "nightlatch".
