Batteries
swbradley1
Modertator
1,705
Dayton, OH
I have a U6TL in mine and they carry them at Interstate Batteries. The other is a regular Interstate battery and I'm going to try and replace them both this week with some regular off the shelf batteries from Wally World or AutoZone.
U6TLs are 825 CCAs so I think I can get by with non-military.
steve
1stDeuce
15
Farmington, NM
I went to the local junkyard... For $25 each they have tested take-outs with no warranty other than if you get it home and it's junk, they'll give you another. (If asked, they'll bust out the tester for you, so you can see that they're good batteries before you take them.
Better yet, for $35 they have "reconditioned" batteries with a one year replacement policy. I figured this was the way to go and got two similar sized batteries. They start the deuce great, and though one proved to be week when I cranked on it for a while w/o the fuel pump running (bad connection at the tank), it was replaced free of charge with one that they tested before giving it to me. (I didn't have them tested when I picked them up, so it was probably weak when I got it.
I figure that no more than I use the truck, the batteries are going to sulfate and die early anyway. So for $70 I got two healthy batteries that whip the deuce over just as well as 6TL's, if not better!
Just an idea.
C
1,808
I have the NAPA $45 specials in my TN deuce and it starts great every time. The tractor had Chinamart specials that worked for 4 years
tie6044
42
Blaine, MN
I went and got a couple 875's from Wal-Mart and they crank great, they are a little smaller in size than the stockers so they don't fit the bracket but they work fine.
gimpyrobb
dumpsterlandingfromorbit!
27,786
752
Cincy Ohio
Get a solargizer and they will last a long time. When I got my "urban camo" deuce, it had some crappy batts. I charged each one seperately and put them in with a solargizerand have been running them since I got the truck. Thats about 2-3 yrs now.
Flea
10
Northeast TN
Two "Never-Starts" from Wal-Mart. I say that kind of tongue-in-cheek because they have always cranked the truck over, even when one was leaking acid. 625 CCA for $35.00 each with 3 year replacement.
