Csm Davis
- 381
- 83
- Hattiesburg, Mississippi
What I want to know is why 6tm batteries are rated so low for their size, you would think they would be rated higher.
Fancy name for where to connect the military style jumper cablesShow my ignorance "Slave connector"?
The way you have your 2 battery setup drawn will work. You'll have some spare links you don't need anymore. Hold on to them to use in the future if needed.I love engineering/welding/fab'in but 'lectrics - not so much. So if someone can check this - it may un-muddy the waters a little: but what to do with all those spare links!
That is how it is in the -10 diag though I don't think the reproduction scale makes that clear. I haven't hooked up a 12v +ve yet on my two cAt batteries yet, but that would be the way I'd go... Though I think I've read else where on here that 12v would be better obtained from an inverter (technically a step down transformer) to get 12 from 24 thus not unbalancing the two 12v batteries by drawing current from just one.You also need to make sure you hook your small 12v wire right when going to two batteries. It should be hooked up to the positive side of the battery that has the negative going to ground. Does that make sense?
