Battery Advice needed
cobratodd
Connecticut
Lots of threads here on batteries, so at the end of the day; with all of your lessons learned, what would you recommend to someone who has a 5 Ton with 4 dead Hawker HASP-FT 6TL batteries?
I have read about the Optima Redtop option, I don't like the idea of cutting back so much of the capacity.
Found lots of other options with less CCA for less money
Read about reconditioning the existing, but I believe I actually lost a few of the cells because after 48 hours on the trickle charger, I'm still only getting 6 or 9 volts on two of the batteries
It's so painful to drop $360 each on 4 milspec batteries - the cost of ownership is going to kill me - I may have to unload my machine:(
91W350
57
Salina, Kansas
2 8D batteries, easy to wire in, slight mods for battery tire down. You will like them. We are using them in several trucks. Glen
73m819
314
gainesville, ga.
I use two 8Ns in the m819, my thought is if two of these batteries will start a D9 or a D10, they WILL start my 855, 250. my first set of blems in 04 cost me $120, $160 later in 09 when I needed another set
3dAngus
101
Perry, Ga.
I paid $125 for an unused Hawker battery at the Ga. Rally. I believe he ships. Check the classifieds, or use search. He still has a lot of them left from people who did not make it to the rally.
sigo
Lieutenant Colonel
359
Leavenworth, KS
I went with the 2 out of 4 good 6TLs that came with my truck, and 2 new group 31s. The GP31 requred a slight mod to the battery box and a new hold down that took about 30 min to figure out and fabricate. It has worked great for almost 2 years, even through a Michigan winter. It will crank strong on just two GP31s, but I never tried it in cold weather or extended periods, just as a quick test.
1,814
Mikev was the seller. A super stand up guy. I just ordered a boatload of CR123A batteries from Mike. Should have got more at the rally.
cobratodd
Connecticut
Very interesting - I'm going to try to recover what I have, then if that doesn't work - I'll try the 8D or 8N option. Awesome information - thank you to all for the advice!!!!
emmado22
138
Mid Hudson Valley NY
Zap the hawkers with high amps for a long time with a CONSTANT VOLTAGE charger. They should come back. This info came right from a Hawker Engineer when I had the same problem. They came back to life.
1,168
I read the thread title and thought you might be offering us the voice of authority and tell us the final ruling of what's best.:idea:
Like something other than what the other hundreds of battery threads have covered.:deadhorse:
Nope, you posted a non-conclusive and un-educating post.aua
Could you please simply explain why you chose your thread title?
1,168
Title Fixed!
Remember, when others search in the future, they make decisions(what to read) based on thread titles.
People often complain about the search function, when in fact they can improve it simply by titling there thread properly.
Also, did I miss which truck you have? The multi-fuels and the Cummins each have their own needs(imho).
MyothersanM1
19K M1 Armor Crewman
402
68
Culver City, CA
M818: I installed two Group 34's (ea. rated @1000 CA and 795 CCA [32° F]) from Costco. I don't have extreme cold weather issues in So Cal so two are plenty. See pic for how they fit with original tie down and some wood blocking (2 X 6 and 2 X 4 with measurements written on them).
6x6TRex
Flint, MI
M818: I installed two Group 34's (1000 CA and 795 CCA) from Costco.
BAD IDEA! Do not use two batteries of different CCA! The smaller CCA battery will draw down the higher CCA battery and shorten its life. Have had a couple farmers come into work to buy 2 new group 31s because they used two with different CCAs.
Its the same principle when you tap one battery for a 12V feed. Always pair your batteries together: age, voltage, and CCA!
MyothersanM1
402
68
Culver City, CA
Clarification: They are the same batteries each having temperate and cold weather ratings:
Group 34
Cranking Amps (CA) 1000/ Cold Cranking Amps @ (32° F) (CCA) 795
The ratings are listed on the red portion of the batteries in my pic.
I wouldn't pair up dissimilar batteries.
An additional note, they are also wired up to a Solargizer.
plumkrazy
Abilene Tx
Brian--How long have these bats. been installed? Do you get the same length of service, if you have no odd electric problems, with 2 batteries as compared to 4?
Regards--Allen
MyothersanM1
402
68
Culver City, CA
Regards--Allen
Installed for about a year now so still evaluating length of service time. No electrical problems whatsoever. In the warm climate of So Cal the extra cranking power is not needed from four batteries. I'd imagine that you might have the same weather conditions in TX. However, I can upgrade to four if I ever need to.
Cycletek
Panguitch, Utah
I have 2 Red Top Optima 1000 CCA's for my 24v and I have 3 Red Top Optima 1000 CCA's for my 12 volt accessories and my 2500 Watt 110 volt inverter, I get my 12 volt charging through a Vanner Equalizer till I install my 200 amp 12/24 HMMWV Alternator, plenty of power!
roflroflrofl
Tow4
622
Orlando, FL
I have two group 31 batteries in my M818. I can't remember exactly, but they are about 1100 CCA. Starts fine.
