Battery Box Size
renovate7
Florida
Can anyone supply the dimensions of the battery box? I'm going to get 2 heavy duty automotive batteries locally. The specs say the 6tl are 10.75x10.25x9 high. I want to make sure the local batteries will fit. Does anyone have a battery group # they are using now?
moreorles2
Freedom, NH
:?: Don't want to hijack the post but it's as good a place as any to ask. One of my spring projects is to sand/prime/ and paint my battery box. Is there any readily available acid resistant coating that anyone can recommend for the inside of the box in lieu of the standard Rustoleum ? I know that the Army went to plastic boxes because they could not stop the rust and corrosion. I was hoping that someone in the SS roster might have had better luck? Thanks ----> Les
EdMontana
TN
I would sand blast the box first, that's the only way to get rid of the rust in pitted areas, use a two part polyurethane based primer and finish with truck bed liner like the Rhino brand, now they sell in gallons and quarts and you can just apply with a roller.
renovate7
Florida
I had done a search under battery box but could not get any good info. I'm going to get two batteries at the local Walmart of all places. They seem to be everywhere in case of warranty issues and have good prices. May paint the label satin black so they don't look so bad, I did this on the 151A1.
